How to hook up a MBC
No you cant just hook up a mbc and crank it up. Your car/ecu isnt "smart enough" to compensate with added fuel/timing adjustments to make any extra boost over stock useful. 00+cars/ecu's can get away with it by doing the diode mod because there is a map sensor- and the ecu will compensate. If you just crank the boost up on a 97-99.5 engine it could cause very very very bad things. Like severe detonation. Get a chip.
soooo what i understood from all this, my setup should be...(2000 1.8MFWD)
DV= 710N
diode= 4.3v?
MBC= bleed/ ball & spring combo? was thinking either
http://voodooboost.com/boost_control...doo_IV-HP_MBC/ -or-
http://www.joepmbc.com/mbc.html the xz one
and not bypassing the N75 for smooth, but strong, accel.
also getting a boost gauge and possible A/F...
sound pretty solid?
DV= 710N
diode= 4.3v?
sound pretty solid?
