DIY - Do It Yourself Within you will find how-to's on many aspects of modding and caring for your ride as told by your fellow members.
How to hook up a MBC
Old Jul 22, 2007 | 11:10 AM
  #61
onepoint8tee's Avatar
Default RE: How to hook up a MBC
No you cant just hook up a mbc and crank it up. Your car/ecu isnt "smart enough" to compensate with added fuel/timing adjustments to make any extra boost over stock useful. 00+cars/ecu's can get away with it by doing the diode mod because there is a map sensor- and the ecu will compensate. If you just crank the boost up on a 97-99.5 engine it could cause very very very bad things. Like severe detonation. Get a chip.
Old Jul 22, 2007 | 12:50 PM
  #62
Audi_Skydiver's Avatar
Ok, thats what i thought. [:@]
Josh
Old Aug 16, 2007 | 06:08 PM
  #63
kraylon's Avatar
after bypassing the n75 with a mbc is it a good idea to plug the 2 prongs on the n75 or leave them open?????
Old Aug 16, 2007 | 07:48 PM
  #64
cincyTT's Avatar
I'm make believe
I have mine open still, but youprobablyshould cap them
Old Aug 16, 2007 | 10:35 PM
  #65
kraylon's Avatar
just put a small peice of hose over them and clap the ends
Old Aug 21, 2007 | 07:27 PM
  #66
pyongwonse's Avatar
soooo what i understood from all this, my setup should be...(2000 1.8MFWD)
DV= 710N
diode= 4.3v?
MBC= bleed/ ball & spring combo? was thinking either
http://voodooboost.com/boost_control...doo_IV-HP_MBC/ -or-
http://www.joepmbc.com/mbc.html the xz one
and not bypassing the N75 for smooth, but strong, accel.
also getting a boost gauge and possible A/F...
sound pretty solid?
Old Aug 21, 2007 | 08:17 PM
  #67
Jeff's Avatar
Zombie Defense Force
that sounds good. you want a bleed type mbc cincytt says they are the best for your car. i have never used this type so i cant say forsure.
Old Aug 22, 2007 | 03:03 PM
  #68
pyongwonse's Avatar
awesome thanks
Old Aug 22, 2007 | 09:13 PM
  #69
cincyTT's Avatar
I'm make believe
That voodoo one is the knock off of mine and my mbc works really well.
Old Aug 23, 2007 | 04:32 PM
  #70
pyongwonse's Avatar
should i get the 4.3v or the 4.7v? does it really make a diff?
