2001 A6 Bose stereo upgrade
Old Mar 4, 2009 | 12:33 AM
PREDATOR's Avatar
Default 2001 A6 Bose stereo upgrade
As t says. My Audi has the Bose system in it. Will this take a double DIN, or just a single DIN? I did a search on here and found out about some things but would like to have it all in one topic for me as well as future members.
I want to achieve the following:
1) Aftermarket DVD head unit, single or double din
2) Subs, do they make a enclosure that uses the quarter panel area and not just a box in the middle of the trunk? Anyone use a free air sub in the rear deck?
3) Component speakers front and rear
4) Amps
5) A list of any/all adapters needed
6) Wiring codes
Information is good, but pictures of the installs is even better!
Thanks.
Old Mar 17, 2009 | 11:20 PM
turbofarts's Avatar
Member
if you are installing an aftermarket head unit, you should have a nice RCA output that you run into your amp. you can, from this point, just remove the bose sub (not sure if you want to remove the amp as it may power the speakers...i personally don't have the bose system). a very popular install technique in A4's and A6's is creating a fiberglass enclosure that pops into the rear driver side cubby in the trunk. if you do this, you will need to get down and dirty with some fiberglass resin and cloth as nobody manufactures these. it is time consuming but not too hard. i'm planning on doing this soon and have collected a lot of links that you might want to take a look at to get a feel for the work involved.
http://picasaweb.google.com/baschuk/...56083429641010
http://www.audizine.com/forum/showthread.php?t=238726
http://www.a4mods.com/index.php?page...s/subbox2.html
Old Apr 4, 2009 | 01:42 AM
PREDATOR's Avatar
Thanks for the links, great information. Who makes a install kit for a single din, in a 2001 A6? Pictures of kit/radio installed would be good as well, thanks.
Old Apr 6, 2009 | 08:48 PM
haveitall's Avatar
I am replacing my 2003 Bose with a dual DIN - writing it up on another forum (.us )
What I did was buy a new bezel, bought a dual din radio with preamp out. Reusing the Bose amp. Bought the plug converter online (though that turns out to be relatively unnecessary...).
However, I have not yet gotten it to work (I won't go into it in your thread). I have only spent an hour or so messing with it though.
Let me know if you want more info.
BT5150
Jan 30, 2010 05:46 AM
yesss4
Dec 26, 2007 03:35 AM
Raouldukey
Nov 4, 2007 06:28 PM
pinkthing
Jan 25, 2007 07:24 AM
