75x Switched Power?
I have a '03 A4 and have been trying to find the "switched power" under the knee bolster. From others on this forum I've heard that I should be looking for something that says "75X," but I can't find it anywhere. Does anybody know if there's somewhere else I should be looking?
I'm trying find this, insert a red T-tap that's connected to my satellite receiver's cigarette lighter adapter so that my satellite receiver will shut off with the car... Any suggestions? Many thanks. |
RE: 75x Switched Power?
Not exactly sure which one it is myself. Do you have a voltmeter? That would be the easiest way to see which terminal puts out 12 volts only when the car is on.
Thanks - I have a voltimeter, and I'll give it a try. I just get very tentative when messing around with the electontics. Clearly, I'm not exactly sure what I'm doing in this dept...
Thanks. |
It is a terminal block with bolts on it in the area under/around the fuse box. You'll see a couple market 30 and one 75X. Loosen the bolt and add your wire. As this is a 12V circuit, ensure you add an appropriate fuse as close to this connection as possible.
