abs problem audi a2
hallo from greece.i need help.i have audi a2 and i have a problem with the abs when the speed of the car reech 20km the abs lamp is on i put the computer to chek the abs and the problemis the left frond speed sensor .i replace the senson but it is doing the same thing ihave check the wares and there are ok .can anyone help me ?:(
RE: abs problem audi a2
what code did you get?? you might have changed the wrong sensor it might be the other side if you get the code I will check for you
you meen the code of the part [the sensor]or the code of the diagnostic tool result.as fer the part i order it from audi with the serial numper of the car ,i dont think that it is wrong .i think that the problem is from the central unit of the abs ???????????i think because i i have changed the sensor i've chaked the wires i've taken out all the wheel and all the prts behind the wheel [i dont know how to write theme down in english ]behind the while it has a plstic think that the sensor takes the signal and that part is ok
the only think that is left to change the sentral unit |
when you ran the diagnostic you will have been given a 5 digit code on your scanner
00283 front left sensor 00286 front right sensor 00287 rear right 00290 rear left |
thanks i will see it tommorow
RE: abs problem Audi a2
no problem mate if you have any problems ill be here;) and your command of the English language is quite good
