Amp killing Battery
Old Aug 2, 2008 | 07:02 PM
zchb9's Avatar
Default Amp killing Battery
Hey guys,
About a month ago I installed my subs and an amp. They work fine the only problem is that when my car sits for a few days the amp drains the battery. It is a 300w mono amp. A friend said it sounds like I need a capacitor, but I was hoping to not have to put anymore money into the system. Any suggestions?
Thanks
Old Aug 3, 2008 | 03:19 PM
98 a4's Avatar
It shouldn't drain the battery if you just have a 300w amp, i have a 1000w kenwood and I have no problem with it draining the battery. what it sounds like is that your amp isn't turning off when the car is shut off...what did you hook up the amp turn on wire to?
Old Aug 4, 2008 | 12:15 AM
zchb9's Avatar
We have the wire hooked up to the remote wire. The Cd player goes off but the amp stays on. Tonight when I reconnected the power wire it blew the fuse in the car for radio #37. Any suggestions? I was thinking of making some kind of toggle switch.
Old Aug 12, 2008 | 05:51 PM
98 a4's Avatar
I'd go with the toggle switch becasue i had the same prob with my amp not turning off with the vehicle so i bought a toggle switch and it works fine now
Old Sep 3, 2008 | 01:48 AM
Sublime865's Avatar
A Capacitor wouldn't directly help, if its staying on its going to kill the battery. You should have a capacitor though to reduce strain on the electrical system during heavy hitting bass. They can be had as low as $50-$60, or $100 buys you a quality one. you'd only need 1 farad at 300 watts (well, less, but I'd stick with 1 farad or more, they also help "jump start" your car if the battery gets low)
Old Sep 19, 2008 | 07:53 PM
Acidic's Avatar
A cap will not help one bit, not even a little. In fact since a cap needs to "charge" in a small way it would hurt....
Do you mean both the head unit and the amp are hooked to the same wire/remote source and only the hu turns off? Also many head units have an amp turn off wire, try using that wire instead of whatever it is connected to now. Otherwise use a multimeter to find any wire that actually turns on (gets +12v) and off (shows nothing) with the car...You could use a toggle switch but that seems kinda ghetto as opposed to just getting it right...
wyze
Apr 4, 2013 11:24 AM
josephap8764
Feb 26, 2007 04:10 AM
PandaXpress
Dec 10, 2006 08:07 AM
