AMP Power cable...
Old Aug 17, 2007 | 05:15 PM
mdre83's Avatar
Default AMP Power cable...
Hi,
I've recently fitted a new headunit to my 2006 A3. I'm looking to fit a sub and an AMP, only problem is, I can't find anywhere(a gromet) to get the AMP power cable from the battery through the bulk head to the rear of the car.
If anyone hasalready donethis, or knows of another way please let me know. Will be much appreciated.
Cheers,
Martin
Old Aug 21, 2007 | 05:03 AM
kraylon's Avatar
Default RE: AMP Power cable...
look for a rubber groment from inside by the pedels sometime you can find on there, other then that sometime you got to make your owen hole just becareful and make 100% sure you know where the end of the drill bit is going
Old Aug 24, 2007 | 07:33 PM
BAMF's Avatar
Do you have manual trans. or DSG? If you have DSG, you can use the hole for the clutch. It should have a rubber plug/boot in it, and it should be large enough to fit any size wire through.
manlio310
Dec 27, 2013 07:07 AM
Mudbone
Feb 23, 2013 12:03 AM
nick212
Jan 20, 2012 03:05 PM
Mac_17
Nov 16, 2007 01:26 PM
