What's the best route for an amp kit?
Old 05-19-2017, 03:58 PM
A4TurboGuy's Avatar
Question What's the best route for an amp kit?
Hi guys,
I've searched every keyword I can think of and all I keep coming up with are super-rookie threads, like "What's a Power Wire?".
I don't mean to sound arrogant, because we all have to learn somewhere, but I've done more systems, in more (diverse) vehicles than I can remember. I even got my MECP cert. because I knew I could pass the test w/o any study at all.
My problem is that my planned route is not going to work. Right now I have everything run down the center, all the way back to where the rear carpet stops (under the center console). It's only like 10 inches of carpet I need to get past/under, but I've found that the carpet is glued down and even if I can get everything under it, you'll see the cables bulging underneath, plus there's a rather sharp edge where the rear bench sits, so that route is pretty much a wash.
My only other realistically viable option is what I would typically do and that's to run everything down the sides (under the kick panel carpet), but this is not a Honda Accord, the plastic kick panels are at least screwed down in some places and the rest seem like they're F**king super-glued to the floor.
Can anyone tell me how to get both sides off (I'm running power down one side and signal down the other, so I need to figure out how to remove all of the panels).
I know someone has this knowledge. Can you please help me finish this thing?
Thanks in advance!
Old 05-19-2017, 07:47 PM
A4TurboGuy's Avatar
Bump........
DewAudiA4
04-06-2013 12:04 PM
tmic0723
10-10-2011 07:46 PM
v8smkr
03-10-2006 04:35 PM
brogenville
01-04-2005 06:42 PM
Quick Reply: What's the best route for an amp kit?
