Can you solve this Audi A6 problem
My lovely A6 is showing the Temp warning sign on the dash ! Its a 1997 model and i have recently replaced thewater pumpunit when it started over heating. Then a few days later warning light came on again but the temp gauge was not going over90 so i replaced theengine heat sensor ! no faults are showing up on the digisnostics computer ??? Im lost now when engine is hot i can open the coolant tank and not muc presure is released which might telll me that the headis not gone no smpke from exhaust etc
Any ideas will be greatfully welcomed i can only think of electrics as a problem or the fact that the water pump went might tell me water was used instead of coolant which might hav caused some hot spots around some parts of engine Many thanks |
RE: Can you solve this Audi A6 problem
maybe the thermostat?
Yea check the thermostat it may be stuck in a slightly closed position.
