connecting iPod or MP3 player
Old Dec 28, 2004 | 06:06 PM
wavecrashr's Avatar
Default connecting iPod or MP3 player
i have an mp3 player that I want to be able to just use a tape adapter with, but for watever reason it won't work. I have the same problem in my new explorer. Is there a setting on the radio I need to select in order to use the mp3 player. I have a feeling that it has to do with the fact that both these new tape players are able to play both sides of the tape without taking it out. In both my 2K2 explorer and 2K1 Audi A4 the tape player keeps trying to figure out which side of the tape to play with the adapter in. What can I do? I dont care enough to wire the mp3 player in - maybe in a little while I'll replace the whole head unit, but right now I don't have the money. Thanks.
Old Jan 5, 2005 | 04:28 PM
yagey's Avatar
Default RE: connecting iPod or MP3 player
there is this product : www.mp3yourcar.com
From what I can tell it plugs in where the cd changer would plug into the harness.
I want to do a similar thing for my sirius hookup, the fm transmitter is useless and the tape adapter solution is horrible horrible quality.
Does anyone have the wiring diagram for the stereo?? I'm no electronics expert but I'm assuming that if I can get the headunit to 'think' there is a cd changer attached (close a circuit?) and feed the line out from the sirius unit into the cd changer line input I might be able to get something to work.
Any advice oh audi experts?
Old Jan 5, 2005 | 04:29 PM
yagey's Avatar
oh and as for your tape adapter problem, get a new better one.
Old Feb 9, 2005 | 09:41 PM
brrman's Avatar
The headunits in our cars are not so simple. Search for something called the Blitzsafe Adapter.
It plugs into the where our cd changer would normally plug into.
Old Feb 15, 2005 | 10:41 PM
jent's Avatar
what about a non-ipod mp3 player....I want to wire my mp3 player into the car that is not an ipod....i have everything to convert it to left right channels (rca connectors). Is there anyway to hook this up into a 96-98 audi a4...what about if i want to keep my cd changer?
Old Feb 16, 2005 | 02:59 PM
Gianluca's Avatar
YES! I have the same exact question. I own the wonderful "Rio Karma" MP3 player (Ogg only, thank you) which has RCA outputs.
I've read a lot about hooking up an external audio source in the past few days and I seem to have found 2 solutions:
1) Use an adapter that will take the CD changer input but I in that case I would lose the CD, and I don't want that.
2) Use the blitzsafe thingy which is basically a splitter, but I'm not exactyl sure how that works. Has anyone here used it? Please explain.
( http://www.blitzsafe.com/blitz_catal...litz_audi.html )
( http://forums.audiworld.com/a4gen2/msgs/218162.phtml )
Please advise!
Cheers,
-Gianluca.
Old Feb 20, 2005 | 06:25 AM
jent's Avatar
ORIGINAL: Gianluca
Please advise!
Cheers,
-Gianluca.
We will solve this one :-)
http://www.logjamelectronics.com/bli...auxdmxv1b.html
according to that site the blitzsafe can not be used with the cd player that does not suprise me at all
but...this --> http://www.logjamelectronics.com/soundsds1.html
used with this --> http://www.logjamelectronics.com/soundockvwf.html
sounds like it would work awsome.....have you seen this? i just stubled across it and from my search so far this is the best thing I have found.
ialso found this --> http://www.logjamelectronics.com/pieaudpcknnsr.html
but it doesnt sound nearly as promising
read that, tell me what you think....does anyone have any experince with these products/brands?
**edit:
After searching for user reviews I was able to find this combo to save a few bux:
http://www.discountcarstereo.com/detail.aspx?ID=649
http://www.discountcarstereo.com/detail.aspx?ID=639
i have never used ether companys but they are cheaper ;-)
Old Feb 20, 2005 | 06:35 PM
chuckie_mn's Avatar
If you use this you have to remove the cable to your changer. They also make one that you can plug in to your changer cable in the back of your car
You have to click the switches to change your audio inputs
I have seen the Blitzsafe used in a VW with an after market cd changer and it worked and sounded just fine.
Old Feb 20, 2005 | 10:37 PM
jent's Avatar
I ordered the cheaper version of that switch kit. I will keep you posted on how the install goes and what happens with my media player. I was going to go to the dealer to have them remove the sterio so I can attach it. I will try to post pics.
Old Feb 22, 2005 | 06:06 AM
Gianluca's Avatar
That's great, jent!
Please keep us updated with what you do and (Yes!) pictures would be great!
Thanks,
-Gianluca.
