Hazards work/blinkers dont
My blinkers have been sporatic for the past few months. when I turneither signal on, it will blinkmaybe3 times at most before it just goes out; sometimes they dontblink at all!! Also, the "ticking" sound somtimes goes out of control when I signal. It can sometimes last for the duration of the ride. almost sounds likea pen down the teeth of a fine comb over and over.However, when I hit the hazard switch, the lights blink just fine. I just want to knowhow to fix it/ or who to take it to,any ideaof the price for parts + labr.Has anyone had this problem?
RE: Hazards work/blinkers dont
Definetly the hazard switch. I had this happen to me about a month ago in my B5 A4, did some research in the forums, so I went to the dealer and paid like $40 for a new hazard switch and popped out the old in plugged in the new and it fixed the problem. I guess there are two resistor coils in the switch (one for hazards, one for blinkers) so that explains why your hazards will work, but your blinkers weren't. Easy fix.........
i had the same problem, i replaced the hazzard switch and the problem was still there. i found the connector at the turn signal switch on the steering collumn was coming unplugged. i secured it back on and now everything works great. hope it helps.
I just had this problem happen to my 87 GT. Both my turn signals and my "Electronic"s board with the Volts and Oil temp are out. I dismanteled the hazzard switch and it wasn't pretty inside so I'm hoping a replacment will cure the issue with the signals.On the flip side, my computer switch now works again after taking apart and cleaning terminals.
Bought the unit, installed in myself 3mins flat. Thanks guys. I love this effin'forum.
| All times are GMT -4. The time now is 07:06 AM. |
