Newbie Turn Signal Question
Old Apr 20, 2009 | 10:01 AM
02Turbo'dQuattro's Avatar
Default Newbie Turn Signal Question
I am a proud new owner of a 2002 A4 Quattro 1.8lt. Had it for two days and love it. The ONLY problem with this car is the turn signal in front on the driver's side. The computer thing between the guages is telling me that the bulb is out and when i turn on the left blinkers it goes faster then the rights. The only one that doesn't work is the front one. So i go in and change the bulb and it is still not working.....
Any solutions?
thanks for all the help in advance
Old Apr 20, 2009 | 10:21 AM
BTW, not sure if this is the place for this, please move if needed, Thanks!
Old Apr 21, 2009 | 03:34 PM
Vhanfinnel's Avatar
You might have to replace the fuse too. Usually when the lights blink fast it's just because a bulb is loose or burnt out, but once you replace it it should work fine, so with it replaced might mean that the fuse is almost fried or you have jacked up wiring.
Old Apr 21, 2009 | 05:10 PM
pa4ul's Avatar
connection from the housing to light possibly or fuse.
Old Apr 22, 2009 | 10:26 AM
ok checked all of the fuses, they look fine. pulled the light again and i noticed that the leads from the actual bulb to the cartridge the bulb goes in are kinda black, i'm gunna try to clean them up and see if that works... if not maybe replace that cartridge.
What's a good site to get Audi parts like that?
Thanks!
Old Apr 26, 2009 | 10:38 PM
Dylan19's Avatar
maybe its the bulb holder. the plastic piece that the bulb sits in. that was the problem with my car. to test i just swapped the right (bad one) with the good left one and it worked. i went to the dealership and it cost me like $15 for a new one.
Old Apr 27, 2009 | 10:41 AM
Actually just figured it out last night, It was that holder thing... one of the leads on it wasn't touching the inside of the housing. Just gently bent it out a little bit and vouala!
Thanks for the help guys!
Old Apr 27, 2009 | 04:25 PM
Dylan19's Avatar
hmmm didnt even think about that.. ohhh well
Pbcrazy
Jun 11, 2013 04:09 PM
Mikesa6
Mar 18, 2010 11:09 PM
PluschakovP
Jan 20, 2009 09:51 PM
4aidua
Apr 22, 2008 02:49 PM
Philthykins
Dec 3, 2007 11:19 AM
