No map lights and central lock dwitch
Hi!
I’m hoping someone can help. I’ve located an old post here in the forum with the exact same problem, however it didn’t have any replies. Here’s what I have. On a recently purchased 2002 TT Quattro 225 Roadster, I do not have 12v power to the map lights or full-on dome setting when my doors are closed. When a door is open, the lights come on. I’ve bench tested the light/button panel, and it’s fine. Also tried another light/switch panel at the start of the troubleshoot. My second problem; my center panel lock switch illuminates (as it should) when the doors are closed, but doesn’t function. The switch works fine, however, when either door is open. Everything else (remote locking, alarm, window movement when the doors are open) work fine. Any ideas would be great? I’ve yet to scan the CCM for faults. thanks in advance! |
