Odometer LED not display in both top and bottom mileage counter
Model : Audi A4 2.6 V6 year 1995
Problem : both top and bottom mileage counter not display - odometer LED display totally black (location of odometer : inside the speedometer in the front panel) Looking for root cause and solution. Send email to paul_shiu@hotmail.com [IMG]local://upfiles/30360/D2175773751B417FA86C6CAB0F055E39.jpg[/IMG] [IMG]local://upfiles/30360/DE93A1F9BEB4491CBF40D747D2865EAE.jpg[/IMG] |
RE: Odometer LED not display in both top and bottom mileage counter
How did you make out with this problem? I'm having the same issue. I also had the outside temp and shift indicator bulbs burn out awhile ago and fixed it with this procedure....
http://www.12v.org/maintenance/repairs/backlight.php thanks but I'm not sure the odo light is accessible beacuse odo's are typically a sealed unit to prevent millage roll back. |
HI
it is just a bulb with a baynet style connection like the others on the rest of the cluster . please be aware if you buy off ebay most are L.E.D s and need the bulb brightness turned up (same controle that sets the clock) also they have to be connected to positive and negative . so if theye don't work turn ignition off completely and rotate 180 deg . if the led comes out of baynet housing please be carefull how you replace as you can cause a short if your out by 90 deg like i did now there is no power to bulb [:@]. hope this helps. |
| All times are GMT -4. The time now is 03:50 AM. |
