Radio
have an 2005 A6 and the radio will go out from time to time. comes back on and plays fine..then drops out again. I replaced the battery but that wasn't it. Any ideas on what causes that?
Scribin
Mine just went out as well.. |
Your radios
Sounds like you both might have a short on the motherboard. Do you hear anything coming from the speakers? Is it when you hit a bump in the road or is is just happening at different times?
Josh A. Tech/Sales Lead Original Car Audio |
Haven't paid attention will listen today, mine just went out. Turned the car off next drive it wasn't working
Yea you might just have a bad CD mechanism inside of the unit. Or if everything seems to be working on the unit and you most likely have a BOSE sound system, It could be the amplifier. Do you know what the part number is to your radio?
Originally Posted by OriginalCarAudio
(Post 1465740)
Sounds good.. Keep me informed
no sound at all from my speakers but the backlight on the radio seems to stay on, even after the car is off. I'm not sure if its staying on the whole time or if it eventually turns off. could that still be a short?
Yes it is sounding more like a short in the system than anything. Sounds like your unit needs to be replaced.
I actually just pulled the fuse and put it back started the car and it's good now
