Red LED headlight mod!
There is also a spot in your engine compartment underneath your air box (to take off the air box its just a couple small star head screws) to the left of your battery (just to the right of where you ran your wires out of the hood) Theres a rubber seal with a couple hard lines in it, i just poked a hole in it to run my sub wire in and behind my glove box. That would cost you less rerouting to the steering column
did u just change the fog lights and make the red LED is?
If this happens I think it would be pretty cool, the pictures are very ugly, I would like to see the quality a little 'better
__________________________________________________ ____
Let's take a 2.7t a6 00, beginning a bad mess, exchanged for a4, 07 2.0T best idea in my life. Current Mods: debadged, test tubes, and air intake.
Reply With Quote Multi-Quote This Message
There is also a place in your engine compartment at the bottom of your air box (to remove the air box its only a few small Phillips screws) to the left of the battery (exactly where you run the cable outside the tent) There is a rubber seal with a few hard lines in it, I just put a hole in it to run my sub and wire behind my glove box. It will cost less to the steering column rerouting
paulywalnuts446
Feb 3, 2013 02:41 PM
blks4
May 20, 2007 03:04 AM
Influentialstylez
Mar 29, 2007 04:30 AM
