tap into power
Old Nov 9, 2005 | 06:17 PM
kleinma's Avatar
Default tap into power
Hi I posted this in the A4 forum, but maybe its better being here, as people with the knowledge im looking for probably visit this section:
I have a 2004 Audi A4 (1.8T 6 speed if it matters)
I have a valentine one radar detector along with the hard wire kit for it so I don't need to use the power outlet plug.
I used to have this hooked up in my celica and it was really easy to implement because that car came apart a little easier than the audi. I was able to tap into the stereo power for it.
Does anyone know a good spot to tap into 12v power and also a good ground spot near by that? I can go to the fuse box if I need to, but fuse taps are ugly and messy and if possible I would like to tap directly into a wire.
Thanks
Also I am looking for something to hook up my ipod to the stock stereo (the 6 cd in dash one) if anyone has used anything good. I did have a pioneer headunit in my celica with the ipod interface, but I dont plan on putting that in the audi, as the only aftermarket headunit i would even consider putting in would be a fold out screen... (but until then... I need something for the stock stereo)
Old Nov 9, 2005 | 07:26 PM
cary12's Avatar
Default RE: tap into power
The only thing I can think of is the fuse box. That's where I always hook up my radar detectors.
Old Nov 12, 2005 | 11:28 PM
BFlan2001's Avatar
remove the knee bolster (four 8mm bolts, three on the front, one on the side at the bottom of the fuse panel), you'll see a few power posts there. you'll want to use the yellow post (switched power). the best thing to use would be a 12awg round end connector
Old Dec 17, 2007 | 09:18 AM
basementwaj's Avatar
hi, i am completely in the dark when it comes to electrics and wireing..... But i want to wire my sat radio into the cars switched power supply. Does anyone have any step by step basic instructions for me?? i am mounting the raid just above the fuse box in my wifes '03 A4.
Thanks!
Old Dec 18, 2007 | 08:33 AM
seanko04's Avatar
If you have a sunroof you can har wire it to your sunroof contollers. Here the DIY
https://www.audiforums.com/m_279694/tm.htm
Old Dec 21, 2007 | 02:36 PM
A6Bman's Avatar
Basement, search for hard wire in this forum or audiworld...there has to be someone that has done that before into the fuse box.
suuntotim
Jul 25, 2011 12:36 PM
99BlackA4
May 22, 2006 08:43 PM
