Unable To Program My Garage Door Opener... Please Help
Hey All,
I recently bought a used 2005.5 Audi A4 2.0T. I am currently trying to set the garage door opener but have been failing every time. I have done the following process without success: Step 1: Hold buttons 1 and 3 until the light starts flashing rapidly Step 2: I selected button one as my primary remote and it started flashing slowly Step 3: I went to the drivers side front bumper and used a remote to enable the copying process Step 4: The hazards flashed the required 3 times to indicate the code was copied Step 5: I turned off the power and then turned it back on to test the garage opener, but failed I have also tried to use the opener immediately after getting the three flashes as well but still failed. Do I also need to hit learn on the actual garage as well, even though the process is replicating the code from the remote I was using? Any help on this would be great thanks everyone! |
Had the same problem with my A4 as well. Tried the whole push the buttons, use the bumper till the lights came on. Nothing worked.
I reset all the buttons, pushed the learn button on the garage door opener, and programed the buttons on the visor. Now it works with no issue. |
| All times are GMT -4. The time now is 10:46 AM. |
