AudiForums.com
-   Exterior (https://www.audiforums.com/forum/exterior-31/)
-   -   Center Caps (https://www.audiforums.com/forum/exterior-31/center-caps-187353/)
kirkj91 09-15-2012 05:54 PM
Center Caps
So I have an 06 A4 quattro and the paint on the center caps is coming off and they are starting to look pretty tacky. I found replacement parts but they are not cheap $65 a piece. I was wondering if anyone knew where I could find them cheaper, or if the B6 center caps would fit on my B7 A4 as they are much cheaper to buy?
pa4ul 09-17-2012 03:45 PM
have u checked ebay?
Jeff-AudiUSAParts 09-17-2012 06:16 PM
For the small 2-3 inch ones they run 25-31.00 dollars, the larger about 6 inch ones are in the 41-55 dollar range depending on wheels on the car. If I had your vin number I can identify what it should have, then compare that to what you have now in case the wheels were changed.
