HID ballast placement A6 (2000)
Good day,
I have installed an H1 hid conversion kit on my 2000 model A6 however i am not certain on where is best to fix the ballasts to. I wondered if you had done it before or could recommend a suitable place? The ballasts don't seem to be of the slim type and came supplied with what looks to be self tapping screws with a bolt head on. Would it be stupid to use heavy rubber bands to strap them on? Thanks in advance regards will |
I've mounted them (in an A4) on the crossmember beneath the headlights. It's convenient for mounting, keeps them out of the way, and they fit fine.
Thanks, I checked that but the cables are too short :-( at the moment I am using cable ties with them tied to the fresh air intake on the passenger side and I think it's the brake fluid reservoir in the driver side. The ballasts are sitting securely but I am not sure if there is any danger or problem with them being there.
What's your thoughts?! |
