Exterior Talk about your rims, body kits, and other exterior mods here.
tail light is dimmed
Old Aug 18, 2008 | 08:25 PM
spydrflash02's Avatar
Default tail light is dimmed
ok so i searched and searched to find a answer or a solution but couldnt..... sooo both rear fog lights and right tail light are very bright and workig fine but my left tail light seems so much lighter then the others could this be the bulb or maybe the wiring?
Old Aug 19, 2008 | 10:37 PM
so no one had ne idea?
Old Aug 20, 2008 | 03:11 AM
andry's Avatar
this is bulb problem, try exchange the bulb (from left tail light to right tail light and vice versa). and see what's happen.
is right tail light still very bright?
Old Aug 24, 2008 | 11:43 PM
Retard Riot 686's Avatar
A little info helps what kind of car do you have?
Old Aug 25, 2008 | 03:05 PM
sry its an 02 a6 2.7t
Old Sep 20, 2008 | 02:24 PM
Prizmatik's Avatar
Try the method "andry" suggested. If you are still having an issue, you probably have a wire grounded somewhere. Then you will need to follow the wiring to see if you can find a ground issue. I hate electrical problems. Good Luck!
MagicHobo
Nov 14, 2008 01:37 AM
haha01
Aug 19, 2008 09:37 AM
smoovmusicdj
Aug 22, 2007 10:27 AM
audi ace
Jul 22, 2005 01:53 AM
