01 A6 Brake Squeal
Old Oct 18, 2007 | 03:44 PM
jmthom's Avatar
Default 01 A6 Brake Squeal
Incredibly painful brake squeal from frt brakes at 10 mph or less. 2 new rotors, 3 sets of pads, two dealers and a tire store later, no one can figure it out. Recentlly replaced front tie rod ends and CV boots, alignment and tire balance. Any help is gratefuly appreciated. 2.7T, auto-stick 71k miles.
Old Oct 18, 2007 | 04:09 PM
AWDaholic's Avatar
Senior Administrator
Default RE: 01 A6 Brake Squeal
swing by your local auto parts store and pick up some brake lube.
pull teh wheel
pop out the pad
swipe a finger (-ish) of lube on the back of each pad
re-install the pad
re-install teh wheel
drive
come back here to tell us if THAT fixed your noise problem
Old Oct 18, 2007 | 04:12 PM
jmthom's Avatar
Had this done 3x already at the dealer, including cleaning the pad surfaces.
Old Oct 18, 2007 | 04:29 PM
AWDaholic's Avatar
Oh, ok, then I'm out of ideas.
you SURE the dealer lubed the backs of teh pads?
Pull one of teh wheels yourself, and see.
Old Oct 18, 2007 | 04:36 PM
jmthom's Avatar
Will check and see. Thanks for the replies. I'll re-post if/when/ever there is a solution.
Old Oct 18, 2007 | 06:54 PM
IDUA ORTTAUQ 6A's Avatar
My experience with brake squeal is due mainly with CHEAP brake pads!
There are expensive, mediocre and CHEAP brake pads available on the market. Choose CHEAP and you will have squeal!
Old Oct 18, 2007 | 10:00 PM
jmthom's Avatar
I agree. The pads are OEM from Audi dealer. Does this mean they're cheap pads?
Jackmup
Mar 14, 2012 02:16 PM
Soundchasr
Nov 16, 2010 08:24 PM
cantdrive55
Aug 28, 2010 02:01 AM
spex
B7 Models
Feb 20, 2008 10:45 PM
Quis
May 27, 2006 03:29 AM
