02 3.0 A4 - Throttle Position Sensor
I threw a code yesterday while driving about 80mph on a local interstate. The EPC & Trac Ctrl lights came up.
I hooked it up to a scanner and had a fault for Throttle Position Sensor - Signal C.
Anyone know common causes/fixes?
2002 Audi A4 3.0L Quattro Automatic 54,000 miles.
I also have a CEL light on, but that is for an unrelated Coolant Temperature Sensor.
You have to adapt the throttle body in basic settings with the audi factory scan tool in both blocks 60 and 63, if that doesn't fix it you will need a TPS sensor.
The coolant temp sensor always take a crap in audi's, replaced thousands of them.
Camshaft adjustment huh? Has anyone ever taken off the cam gears for any reason, i know there is a special tool that seats them before you install the timing belt which can cause a camshaft fault.
