05 Audi a3 3.2 quattro AWD controller error PLEASE HELPP
Hi All,
i have the following error from my ABS & AWD modules. I have been reading up and it looks like its either the Haldex controller its self or possibly the pump??
if anyone could provide some direction that would be awesome
Output below:
Address 01: Engine Labels: 022-906-032-BDB.lbl
Part No SW: 022 906 032 GL HW: Bas isX 3
Component: MOTRONIC ME7.1.1G 7000
Revision: 00000000 Serial number: AUX7Z0D8FNK03O
Coding: 0000178
Shop #: WSC 06314 000 00000
VCID: 5B9B72F79AA1A7C6A11-800E
1 Fault Found:
16825 - EVAP Emission Control Sys
P0441 - 002 - Incorrect Flow - Intermittent
Readiness: 0010 1001
Address 02: Auto Trans Labels: 02E-300-0xx.lbl
Part No SW: 02E 300 046 D HW: 02E 927 770 AA
Component: GSG DSG 0632
Revision: 03149888 Serial number: 00000408180270
Coding: 0000020
VCID: 18112DFB2B178CDE4C3-804D
No fault code found.
Address 03: ABS Brakes Labels: 1K0-907-379-MK60-A.lbl
Part No: 1K0 907 379 E
Component: ESP ALLRAD MK60 0104
Coding: 0021128
Shop #: WSC 06435 000 00000
VCID: 3449F94B57BF48BE40B-8061
1 Fault Found:
01324 - Control Module for All Wheel Drive (J492)
013 - Check DTC Memory - Intermittent
Address 08: Auto HVAC Labels: 8P0-820-043.lbl
Part No SW: 8P0 820 043 F HW: 8P0 820 043 F
Component: KlimavollautomatH12 0150
Revision: 012391 Serial number: 8P0820043F
VCID: 2F43F627BE996B663D9-807A
Address 09: Cent. Elect. Labels: 8P0-907-279-23-H.lbl
Part No SW: 8P0 907 279 C HW: 8P0 907 279 C
Component: Bordnetz-SG H34 0301
Revision: 00H34000 Serial number: 00000001054994
Coding: E58E5F17A014100000000000000000000000FE0F5C
Shop #: WSC 00000 000 00000
VCID: 3D5FDC6F64F589F6BF5-8068
Subsystem 1 - Part No: 8P2 955 119 B Labels: 1KX-955-119.CLB
Component: Wischer AU350 H01 0130
Coding: 00062736
Shop #: WSC 00000
Subsystem 2 - Part No: 4E0 910 557 Labels: 8K0-955-559.CLB
Component: REGENLICHTSENSORH10 0040
Coding: 00150573
Shop #: WSC 00000
Address 15: Airbags Labels: 8P0-959-655-84.lbl
Part No SW: 8P0 959 655 D HW: 8P0 959 655 D
Component: Airbag 8.4ED H00 0140
Coding: 0410603
VCID: 43ABAA970211FF06C91-8016
Address 16: Steering wheel Labels: 8P0-953-549-F.lbl
Part No SW: 8P0 953 549 F HW: 8P0 953 549 F
Component: J0527 H36 0070
Coding: 0015142
Shop #: WSC 06447 666 47511
VCID: 41A7A09F180DED16DBD-8014
Subsystem 1 - Part No: XXXXXXXXXXX
Component: E0221 H02 0100
3 Faults Found:
01303 - Telephone Transceiver (R36)
004 - No Signal/Communication - Intermittent
01044 - Control Module Incorrectly Coded
000 - - - Intermittent
01301 - Control Module for Voice Recognition (J507)
Address 17: Instruments Labels: 8P0-920-xxx-17-MY7.lbl
Part No SW: 8P0 920 930 M HW: 8P0 920 930 M
Component: KOMBIINSTR. VDO H71 0210
Revision: D03 Serial number: 2248DD03003923
Coding: 0001718
Shop #: WSC 42150 822 83344
VCID: 3C59D16B7FEF80FE88B-8069
Address 19: CAN Gateway Labels: 1K0-907-530-V1.clb
Part No SW: 1K0 907 530 D HW: 1K0 907 951
Component: Gateway H08 0100
Revision: 08 Serial number: 25001048310C08
Coding: FF0F0348070101
Shop #: WSC 06314 123 12345
VCID: 28711D3B9B773C5EFC3-807D
Address 22: AWD Labels: 1K0-907-554.lbl
Part No: 1K0 907 554
Component: HALDEX 4Motion 0101
Coding: 0000001
VCID: EAF5A733C5FB4E4EAA7-80BF
2 Faults Found:
00003 - Control Module
014 - Defective - Intermittent
02248 - Valve for Controlling Clutch Operating Angle (N373)
Output below:
Coding: 0000178
1 Fault Found:
Coding: 0000020
Coding: 0021128
1 Fault Found:
Coding: 00062736
Shop #: WSC 00000
Coding: 00150573
Shop #: WSC 00000
Coding: 0410603
Coding: 0015142
3 Faults Found:
Coding: 0001718
Coding: 0000001
2 Faults Found:
chriscurra
06-13-2015 02:44 PM
Ergokinetics
05-07-2007 09:09 PM
