1992 Audi 100S Thermostat????
Can anyone tell my the location of the thermostat in this car and if possible point it out on a picture? I've done other minor repairs (brake jobs and that kinda stuff) to this car but I need help.
Thanks
AS
Thanks
AS
RE: 1992 Audi 100S Thermostat????
http://12v.org/engine/index.php?sect...&view=cool
just to let you know you need to take the t-belt to get the t-stat housing off
http://12v.org/engine/index.php?sect...amp;view=tbelt
you can see that the t-sta is in that housing behind the t-belt on the left side looking directly at the engine. its held on by 2 10mm bolts. when i did my t-stat it took about 7 hours and that was without removing the belt, i dont suggest this since it can damage the belt, i was able to kind of bend the belt enough to move the housing and pull off out the t-stat.
100, 100s, 1992, 92, audi, change, changing, located, location, removing, replacement, thermostat, thermostate, v6, waterpump
