Go Back  AudiForums.com > Audi Tech > General Tech
2.7 S4 B5 chain tensioner woes >
Old 08-29-2018, 02:05 PM
Default 2.7 S4 B5 chain tensioner woes
Yeah, another one of those questions...
Heads were re-built with some new non-OEM chain tensioners to replace the severely worn stock ones. However, it appears that the tensioners are having trouble getting oil pressure, and it's causing some timing problems. I suppose it's possible that both new tensioners are somehow bad, but that seems kind of un-likely. If the tensioners got switched around during assembly (left to right, since they're sold per side), could this cause an oiling problem?
Old 08-29-2018, 03:31 PM
SoCal Crew Member
Is it even possible to install on the wrong side? Trouble getting oil pressure......time to test oil pressure from the pump?
Old 08-29-2018, 04:12 PM
Good question, I'm not entirely sure. This stuff was done back in March, best I have is looking back at pictures of the engine assembly. Everything looks right. I asked about oiling to everywhere else in the heads, waiting to hear back.
Old 08-29-2018, 08:44 PM
SoCal Crew Member
ill ask a few of my techs tomorrow and try and get some more intel
Old 08-29-2018, 09:20 PM
Appreciate that!
Old 08-30-2018, 12:27 PM
SoCal Crew Member
So doesn't sound like it is possible to install on the wrong head....but there is a small screen on the adjuster used in an oil passage that could have come out of place or is maybe clogged up causing your low oil pressure to the unit. You'll have to uninstall them to check. If that looks all good time to think about the oil pump itself.
jinsojoo
10-30-2012 11:22 PM
keko2004
10-12-2006 11:21 PM
JohnnyBravoA4
07-20-2006 05:20 PM
jcwolfe
03-28-2006 03:56 PM
Quick Reply: 2.7 S4 B5 chain tensioner woes
Advertising
Featured Sponsors
Contact Us - Archive - Advertising - Cookie Policy - Privacy Statement - Terms of Service
© 2019 MH Sub I, LLC dba Internet Brands
We are a participant in the Amazon Services LLC Associates Program, an affiliate advertising program designed to provide a means for us to earn fees by linking to Amazon.com and affiliated sites.
