2001 A4 1.8t engine problems help!
Old Jun 7, 2010 | 11:39 PM
kpadlina's Avatar
Default 2001 A4 1.8t engine problems help!
Doing a compression test all the cylinders were good except 2nd one back while cranking has 158psi then drops to 0 then back to 158 etc. Think a bent valve is the problem? I'm getting 2 knock codes and camshaft position sensor advanced...
Old Jun 8, 2010 | 02:13 PM
R.A.I. Motorsport's Avatar
Former Sponsor
Have you checked the physical timing? The camshaft position sensor is usually the indication of it being off.
Old Jun 9, 2010 | 10:53 AM
kpadlina's Avatar
I haven't actually checked cause I can't see any timing marks on the cam or crank shaft but the belt is tight and looks to be in decent shape... also why would only #2 cyl be the only bad one?
Shawn Miller
Mar 12, 2013 07:17 PM
bpost
Sep 22, 2011 10:36 PM
AudiinNorway
Nov 23, 2010 04:01 PM
audipower
Mar 31, 2009 12:49 AM
dufferdude
Nov 13, 2004 10:58 AM
