2001 A4 2.8L Trans Problem....HeLP!
2001 A4 2.8L Quattro Avant Auto-Tiptronic
A few weeks ago, I noticed the car was slow from a standing start. Then 2 days ago, the car shuttered a bit at running idle while driving. Yesterday, shuttering then a cloud of smoke while driving. Stopped, looked underneath and saw fluid leaking out from under the car between the front wheels. Got it home and up on stands. Wiped everything down and could not for the life of me figure where the leak came from. Looked at send and return line fittings, seals and figured it must be a tranny pan gasket failure. Replaced today with new gasket and filter. Filled with fresh fluid while cold and started engine to get the fluid hot for final topping. Immediately fluid poured out in front of tranny just behind flywheel. I should also mention that there is a whining/almost slight grinding noise that is more prominent when engine rpm is increased. I thought this might be the pump as it was way low on tranny fluid. (The car just basically spit out ALL of the fluid yesterday) https://www.dropbox.com/s/7ghcdeav94..._0729.JPG?dl=0 https://www.dropbox.com/s/4sv0rv4y0c..._0730.JPG?dl=0 You can see the drips...flywheel is dry. So....what do you think the issue is? Fried torque converter? If so, how tough of a home garage repair? Thanks in advance for help! |
Definitely sounds like something has come unglued inside. She's going to have to come out to repair. If it has puked all the fluid out, it's possible that the clutch packs have gotten hot due to slipping. If you do pull it, I'd either have it rebuilt (something I'd love to learn how to do) or find an identical (identical transmission code) lower mileage trans to swap out.
| All times are GMT -4. The time now is 03:59 AM. |
