AudiForums.com
-   General Tech (https://www.audiforums.com/forum/general-tech-50/)
-   -   2001 Allroad Problems - Throttle Body or ? (https://www.audiforums.com/forum/general-tech-50/2001-allroad-problems-throttle-body-80271/)
allroadguy Nov 1, 2007 08:25 PM
Hi, All;
This is my first post here, and unfortunately it's relating to a serious problem with my 2001 allroad. It has the 2.7T engine and 6 spd manual.
I had the alternator die a few weeks ago, and ordered a new one. I decide that I would also install an APR bi-pipe kit while I had the front of the car apart. The alternator install went fine, but the bi-pipe I received from ECS Tuning was the wrong one, and I had to abandon that swap part way through. Once I had the car back together, it started okay but idles very erratically and will not rev above 1200 rpm - basically the throttle is inoperative. My code reader is showing trouble codes 17581 (throttle position potentiometer sgn. 2 signal too high), 17952 (throttle actuation potentiometer signal too high), and 17987 (idle speed control throttle position adaptation not started).
I also have warning lights for the EPS, ABS, and suspension, and I can't get the suspension out of jacking mode - I don't know if these are related to the throttle body problem or just another unrelated problem that happened at the same time.
The only thing I can think of is that I somehow damaged the throttle body while trying to install the bi-pipe kit. It's a $200 tow truck ride to the nearest place that can service the car, so I'm trying to sort this out myself. My first thought is to order a new throttle body assembly, but I would like to eliminate any other likely causes before shelling out $700 for a new TB... any advice would be greatly appreciated!
tHe kNiGHt FaLL Nov 2, 2007 01:37 PM
RE: 2001 Allroad Problems - Throttle Body or ?
you can't just replace the throttle body yourself... it has a control module in it. the control module has to be coded then adapted.
i don't even kno where to start w/ your problems... w/o knowing what codes are present.
allroadguy Nov 4, 2007 09:03 AM
ORIGINAL: tHe kNiGHt FaLL
The DTC codes I listed above are all that are showing...
I removed the throttle body from the intake manifold, connected it to the wiring harness, and it started the adaptation process each time I turned the key on. I reinstalled it, cleared the codes, and now it seems to be working normally.
tHe kNiGHt FaLL Nov 4, 2007 07:52 PM
some reason i didn't see the codes... but still... like i said... the adaptation needed to be carried out.
