87 5kt, rough idle and ecu code 2142
Old Feb 19, 2008 | 01:51 PM
Yentemad's Avatar
Default 87 5kt, rough idle and ecu code 2142
well, i recently did a tune up on my car and now i've got a pretty rough idle and my gas mileage is horrible. I went out before to pull any codes that it had and got 2142, which is a knock sensor problem.
2142
Knock Sensor (KS) #1 (G 61)
Open or short circuit, Defective sensor
Check sensor and wiring
Symptom: Timing retarded, High fuel consumption, power loss, Boost pressure not attained
can anyone recommend a course of action for this before i end up having to come up with the money for a new knock sensor?
Old Feb 19, 2008 | 02:01 PM
techbod's Avatar
Default RE: 87 5kt, rough idle and ecu code 2142
knock sensor is loose or faces are corroded which would impair its reading, a knock sensor is like a timing tool for the engine just like the cam sensor but lower down to crank/mid range and adjusts the timing if there is the need . check the sensor isn't loose and wiring is good
Old Feb 19, 2008 | 02:08 PM
techbod's Avatar
data says 2142 = knock sensor possible fault = wiring/knock sensor/ECM
Old Feb 19, 2008 | 02:13 PM
Yentemad's Avatar
stupid question: where is the knock sensor on this car? my bentley manual doesnt really say anything about it
justinclarke
Nov 25, 2010 04:03 PM
jbangsund
Apr 1, 2010 04:19 PM
ljschnel
Sep 1, 2009 11:33 AM
97A41.8t
Jan 21, 2007 12:08 AM
