95 A6, oil leak (steady drip)
Old Nov 2, 2005 | 10:00 PM
polar's Avatar
Default 95 A6, oil leak (steady drip)
so i just changed my oil today in my A6 (2.8). when i pulled off the oil filter, the entire shaft that goes through the oil cooler into the oilpan came out with it. i talked to a tech at the audi dealer and he said i should be able to thread it back in, throw the filter on and be fine. well, i did that. now i'm losing ALOT of oil from that fitting (not where the filter meets the oil cooler, but where the cooler meets the oilpan.) is there a gasket or o-ring back there that i could've fucked up?
Old Nov 6, 2005 | 12:42 AM
dankhound's Avatar
Default RE: 95 A6, oil leak (steady drip)
Theres an o ring on the backside of the oil cooler. There is also supposed to be a 22 or 24mm nut on the shaft that holds the oil cooler on.
redmond1501
Mar 24, 2013 02:28 PM
a6.nh
Aug 9, 2010 08:36 PM
oc_audica
Sep 17, 2008 07:27 PM
Bantanic
Apr 12, 2006 03:16 PM
