96 A4 tranny wont go in reverse
Old Feb 26, 2009 | 11:26 PM
MDsA4's Avatar
Default 96 A4 tranny wont go in reverse
So my girls got a 96 a4, we live in northern illinois and we had floods all over tonight. She decides to go through a big *** puddle of water and now the trans wont go into reverse. Drive and Park work fine. Any ideas?
Old Feb 27, 2009 | 12:34 AM
auditech79's Avatar
You mean you can't force it into reverse or it just doesn't work?
Old Feb 27, 2009 | 12:49 AM
MDsA4's Avatar
I can put the shifter in reverse but the tranny wont engange. When I put it in reverse it stays in neutral.
Old Feb 27, 2009 | 07:58 AM
sprngbokA6's Avatar
Have you replaced the fluid recently? Filled it up? Trans fluid should be done every 10k miles, if it is not can lead to corrosion of parts in the trany...this sounds like this one is done sry to say.
Old Feb 27, 2009 | 12:09 PM
MDsA4's Avatar
No the trans works fine, when its in drive it shifts normally and when i put it in park its fine also. Is there a trans switch on these cars and where is it located?
Old Feb 27, 2009 | 03:40 PM
auditech79's Avatar
I would say its a bad TR (transmission range) switch, have the dealer check the fault codes in the TCM. If you have a vag com or know someone with one have them scan it and save some money. Its most likely a electrical error if the car still shifts going forwards.
Old Feb 27, 2009 | 09:45 PM
MDsA4's Avatar
I thought it would be somethin like the trans switch, is this easy to get to? I know its on top of the trans and how much would it cost for one?
Old Feb 28, 2009 | 08:28 PM
auditech79's Avatar
No im talking about the switch thats under the chrome shifter plate. You have to remove the shift ****, the wood trim around the shifter, pop up the chrome plate, and replace the switch under the plate. It looks like a green circuit board.
rough pearl
Jul 6, 2012 10:55 PM
tee-A6
Feb 26, 2011 03:02 AM
umoms
Jun 21, 2008 01:17 AM
Frails
Aug 18, 2007 02:34 PM
18ToHATE
May 31, 2006 10:35 PM
