96 A6 Slow Guages
Old Feb 26, 2007 | 10:53 PM
TBM's Avatar
TBM
Default 96 A6 Slow Guages
My 1996 A6's coolant and oil temperature guages barely move off the peg, even after driving 60 miles. All other guages are fine. My independent mechanic gave me, yes gave me, a replace instrument cluster but to no avail. Is this a common problem? Is it a problem with temperature sensors? Thanks for any help.
Old Feb 27, 2007 | 12:54 AM
auditech79's Avatar
Default RE: 96 A6 Slow Guages
In an A6 the cluster is usually not the problem, the problem with the temp gauge is probably the thermostat is stuck open causing the engine not reach operating temp, and for the oil i would check the oil pressure by removing the oil sender and installing a gauge and running the engine. It should be around 4 bar (or 60 psi)
Old Feb 28, 2007 | 03:39 PM
SAudi's Avatar
definetly the thermostat, ive been seeing many of these posts latley, i had the same problem replacing the thermostat really worked, i would also replace the plugs at this time since they are probably fouled.
merino1993
Oct 20, 2012 06:18 PM
MKE_Audi
Mar 23, 2012 02:20 PM
2kblacks4
Feb 8, 2007 04:58 PM
2kblacks4
Feb 8, 2007 02:49 PM
Audi90C
Mar 30, 2006 01:55 AM
