97 1.8T low oil light on won't start!
Old 01-11-2006, 02:43 PM
matz445's Avatar
Default 97 1.8T low oil light on won't start!
I posted this question in the A4 section but figured more exposure here. Ok the low oil light came on and the car killed while driving. Pulled over and waited a few minutes and it started and drove another 10 miles. The oil is not low! My main question is will the low oil sensor cause the car to die out? The car will start and idles down slowly until it dies out. Idle control valve? HELP!!!!
Old 01-11-2006, 03:47 PM
Default RE: 97 1.8T low oil light on won't start!
my mates oil light comes on when reved hard but it is the oil sensor his motor dosnt cut out,
[IMG]local://upfiles/12092/3757163A314C4900BCBA21C8707FA8D3.jpg[/IMG]
Old 01-11-2006, 03:48 PM
#2 a couple more to come
[IMG]local://upfiles/12092/99BC56352A5741B5A906DFD6504E1E9A.jpg[/IMG]
Old 01-11-2006, 03:49 PM
[IMG]local://upfiles/12092/68191A48BAEA4A678EFD5B38D457B38C.jpg[/IMG]
Old 01-11-2006, 03:51 PM
#4 I have to send them in seperate posts because of the image size
[IMG]local://upfiles/12092/4C27915FC4DB40A79098BEEA60E1AD23.jpg[/IMG]
Old 01-12-2006, 11:16 PM
matz445's Avatar
Thanks Avant80 for those diagrams. That should help me out a lot. I really appreciate it!
Old 01-13-2006, 03:55 PM
any time mate if you need more information I will accommodate
Old 01-13-2006, 06:42 PM
matz445's Avatar
Well the timing belt broke!!!! OUCH. Anyone want to buy a non running A4? I'm sure these are interference motors right?
Old 01-13-2006, 07:10 PM
owwwwww that's bad it is an interference engine but I doubt you stuffed more than 4 valves, first thing a garage does is fit a new belt because you just might be lucky " I have seen this a few times ", it not such a big deal rebuilding the top end just fiddly and lots to remove but I wouldn't condemn the engine for that
AZMSP84
06-12-2021 05:15 AM
nickselig88
11-26-2014 08:54 PM
pmkcolorado
08-09-2011 04:10 AM
alas
03-26-2007 07:57 PM
matz445
01-13-2006 04:08 AM
Quick Reply: 97 1.8T low oil light on won't start!
