99 A4 mass air flow issues
Ok first off I know nothing about cars! here is what I do know a bout 6 months ago my car started running horrible cutting out, check engine light was on and it ended up being the mass air flow sensor. We replaced it with a new one. Now less its back to running bad runs on only 2 cylinders(if that's right) spits spudders cuts out the Check engine light will either be steady red or flash at me. when you take the sensor off it still runs bad. I was told that if it was the sensor that when you take it off it would run normal. Can anyone help? I really don't want to take it to a shop if I can just order another sensor for it. Any help would be much Appreciate
