A4 3.0tdi power loss !!
Hi
I have a A4 3.0 tdi 2006 last week it started to smoke under acceleration and it went into limp mode couple of times. The car is well maintained it’s had a new turbo new inlet manifolds also new glow plugs. I have no engine management light on so you would think the car is ok unfortunately there is an issue. The garage has checked the injectors and fuel pump all working ok, I have not changed the EGR valve but was advised it’s not a common issue on the 3.0tdi engine. I scanned the car today and no faults were found so I’m lost and have no idea what to do. Any advice would be great full Thanks |
I had my car checked last week turns out the Turbo has failed after 7600 miles. I had the turbo replaced and now the car has no power before 2000 rpm after 2000 rpm its ok.
Any Ideas ? 000564 - Boost Pressure Regulation P0234 - 001 - Limit Exceeded (Overboost Condition) - Intermittent Freeze Frame: Fault Status: 00110001 Fault Priority: 0 Fault Frequency: 3 Reset counter: 255 Mileage: 190898 km Time Indication: 0 Date: 2064.00.00 Time: 00:00:00 Freeze Frame: RPM: 2394 /min Torque: 343.2 Nm Speed: 57.1 km/h Absolute Pres.: 1897.2 mbar Absolute Pres.: 2233.8 mbar (no units): 0.0 Temperature: 19.8°C 013128 - Control Circuit for Controller for Turbocharger 1 (J724) P3348 - 005 - Electrical Malfunction - Intermittent Freeze Frame: Fault Status: 00100101 Fault Priority: 0 Fault Frequency: 28 Reset counter: 255 Mileage: 190898 km Time Indication: 0 Date: 2064.00.00 Time: 00:00:00 Freeze Frame: RPM: 1155 /min Torque: 0.0 Nm Speed: 50.4 km/h Temperature: 52.2°C Duty Cycle: 50.1 % Voltage: 14.36 V Duty Cycle: 12.6 % Readiness: 0 1 0 0 0 |
