Go Back  AudiForums.com > Audi Tech > General Tech
a4 Oil Filter Cap Leak Problems. >
Old 03-10-2019, 01:42 PM
Default a4 Oil Filter Cap Leak Problems.
Is there some problem with the oil filter cap on my 2006 A4 oil filter that I am not aware of? I've replaced the cap twice and the entire oil filter housing assembly before noticing that the cap I had replaced came loose for a 3rd time. It seems like vibration from the motor is what is loosening the cap. Also I am using after market parts. I suspect that is my problem. Is there any known problem using original parts? I don't think my engine is vibrating excessively. How tight is it supposed to go? American cars are usually only hand tight or a little more. I've gone well beyond that.
Old 03-11-2019, 07:52 AM
How did you make a post I’m new to this I can’t even get my problem out there
Old 03-11-2019, 11:07 AM
Apparently just like you did. Your post showed up. Next time just go back and start a new thread with!
Old 03-11-2019, 11:19 AM
Six drops and a very small puddle on the oppisite side of my oil filter this morning.. My mechanic says he tightened the oil filter according to specs. When I did it myself the first time it wasn't that loose and was leaking a drop every second. Maybe the leak is coming from somewhere else. He doesn't have a lift and has to crawl under there to look at it.
I'm thinking of taking it to town, using the car wash and then heading straight to a real mechanic that has a lift to try and see where it's really coming from.
Are there any known problems with oil leaks on this thing?
Maybe before I do that I will make sure it isn't residual oil coming off from the leak before. It was pretty massive and no one ever washed it off but it's been driven at least fifty miles.
I guess it will either slow down or get worse...
A4 Jed
Engine/Performance Parts
06-23-2013 06:13 PM
TuroHernandez
04-08-2013 01:16 AM
Quick Reply: a4 Oil Filter Cap Leak Problems.
Advertising
Featured Sponsors
Contact Us - Archive - Advertising - Cookie Policy - Privacy Statement - Terms of Service
© 2019 MH Sub I, LLC dba Internet Brands
We are a participant in the Amazon Services LLC Associates Program, an affiliate advertising program designed to provide a means for us to earn fees by linking to Amazon.com and affiliated sites.
