AudiForums.com
-   General Tech (https://www.audiforums.com/forum/general-tech-50/)
-   -   Alternator output specs (https://www.audiforums.com/forum/general-tech-50/alternator-output-specs-168390/)
NZ-S-IV May 1, 2011 03:42 AM
Hi all,
I have been chasing a random electrical problem on my B5 S4 for the past 6 months.
Finally got a VAG-COM and connected it up to find that the 'battery voltage' would drop as low as 12.8 while the car is running.
It has so far killed a battery, and caused the ECU to 'lose some code' and had to be reflashed.
I was wondering (because I cant find in the service manual) what the rated output of the alternator should be...in my experience, 13.7-14.1v is standard output for most alternators. For the duration of the logging I did today, it did not go above 13.4 volts - too low in my opinion.
Cheers,
Andrew
Huey52 May 1, 2011 08:12 AM
Concur, with the engine running and applying a voltmeter across the battery terminals you should be reading ~14VDC. Any lower is suspect - degraded alternator windings/bushes, loose belt, loose connections, degraded wiring, etc.
Originally Posted by NZ-S-IV (Post 1308722)
Hi all,
Cheers,
Andrew
