Audi 80 cabriolet roof
Hi - I have an intermittant problem with my electric roof. Sometimes it works with the engine running, it lifts into the vertical, the rear box lifts 100mm then stops. When this happens it is sometimes possible to turn off the engine and turn the key to ignition - no engine - it then may continue to operate sucessfully. When closed it will only open with the ignition on - no engine.
The resevoir is full and the relay on the hydraulic unit has been changed. This fault occurred several weeks ago, then rectified itself, but has come back. Regards Guiness [sm=alcoholic.gif] |
