A1 engine clatter
Old 06-15-2017, 04:11 AM
pugzlee's Avatar
Default A1 engine clatter
Hello
Over the past few months my 2014 A1 1.4TFSI 122PS/90kw engine has been making a clattering/tappet noise specifically as I drive uphill (low gradients) at low revs and/or from 1,500rpm - 2000rpm range on level ground. It started out faint but now the noise has become progressively louder. It is winter time now but I dont believe that cold air can do this because the noise is still produced even though the engine light indicates the engine is warm. I filled it with 5W-40 about 2 months ago if that helps. I took it to the dealership to run a diagnostics on the car last month but according to them there is nothing wrong, still under warranty for a few years.
Its a different noise to the camshaft timing issue that is common with this engine
Old 06-15-2017, 06:33 PM
Hector210's Avatar
Does the ticking increase when you accelerate, and slow as the car slows while engaged in drive or gear?
Old 06-16-2017, 08:38 PM
dave944's Avatar
SW-40? Check to make sure that's not too thick. Check the owners manual and it will tell you exactly what oil weight to use. 40W sounds a bit thick to me.
Old 06-19-2017, 05:08 AM
pugzlee's Avatar
it only makes the clattering sound upon acceleration
Old 06-19-2017, 05:13 AM
pugzlee's Avatar
I called the local dealership and they told me any 5W-40 would do, Ill check the book tonight
Old 06-19-2017, 09:22 AM
dave944's Avatar
Almost sounds like an oil pickup issue. You aren't getting any low oil pressure warnings are you. Also make sure you don't overfill it either. Too much oil can be as bad as not enough with the crank slapping it as it sloshes up to depths that it shouldn't be at.
Old 06-19-2017, 10:46 AM
pugzlee's Avatar
nah, oil pressure reading is fine.
Common65
11-23-2016 09:15 PM
kroogz
01-20-2015 06:09 AM
blakesmithrx785
02-04-2012 04:18 PM
jrseaman
10-27-2008 11:55 AM
dil
06-21-2005 05:20 PM
Quick Reply: A1 engine clatter
