Audi A4 B7 2007 electrical problems
Hi Guys, i bought this Audi A4 B7 2007 2.0 Tdi as a non runner. The previous owner told me that he left the passenger window open(right hand drive) and it rained that night. The following morning he saw a lot of water at the foot well. Tried to start the car but nothing. He had a mechanic to check the car and he found that the central convenience module was fried. It short circuited as the water penetrated it.
Long story short i replaced that module and the car still did not start. So i did a scan and found the following : Monday,22,June,2015,16:26:19:05981 VCDS -- Windows Based VAG/VAS Emulator VCDS Version: 14.10.2.0 Data version: 20150311 Ross-Tech: Home VIN: WAUZZZ8E17A084848 License Plate: AUDI Mileage: 164980km-102513mi Repair Order: -------------------------------------------------------------------------------- -------------------------------------------------------------------------------- Chassis Type: 8E (8E - Audi A4/S4/RS4 B6/B7 (2001 > 2008)) Scan: 01 02 03 08 09 0F 11 15 16 17 18 25 36 37 45 46 55 56 57 65 67 69 75 76 77 VIN: WAUZZZ8E17A084848 Mileage: 164980km-102513miles ------------------------------------------------------------------------------- Address 08: Auto HVAC Labels: 8E0-820-043.lbl Part No: 8E0 820 043 BN Component: A4 Klimaautomat 2833 Coding: 00000 Shop #: WSC 00000 VCID: 6ED576AA2A8058518C3-5102 No fault code found. ------------------------------------------------------------------------------- Address 09: Cent. Elect. Labels: 8E0-907-279-8EC.lbl Part No: 8E0 907 279 N Component: int. Lastmodul ECE 0907 Coding: 01001 Shop #: WSC 06325 VCID: 3D7781E63766F3C9459-4B00 No fault code found. ------------------------------------------------------------------------------- Address 16: Steering wheel Labels: 8E0-953-549.lbl Part No: 8E0 953 549 Q Component: Lenksáulenmodul 0701 Coding: 02041 Shop #: WSC 06325 VCID: 418FFD164B9E9729211-4B00 No fault code found. ------------------------------------------------------------------------------- Address 17: Instruments Labels: 8E0-920-9xx-8EC.lbl Part No SW: 8E0 920 901 D HW: 8E0 920 901 D Component: KOMBI+WFS 4 H14 0110 Revision: 0110 Serial number: 00000000000000 Coding: 0006111 Shop #: WSC 01642 996 08954 VCID: 26454E8A92F05011343-5102 1 Fault Found: 01312 - Powertrain Data Bus 014 - Defective ------------------------------------------------------------------------------- Address 25: Immobilizer Labels: 8E0-920-9xx-8EC.lbl Part No SW: 8E0 920 901 D HW: 8E0 920 901 D Component: KOMBI+WFS 4 H14 0110 Revision: 0110 Serial number: 00000000000000 Coding: 0006111 Shop #: WSC 01642 996 08954 VCID: 26454E8A92F05011343-5120 1 Fault Found: 01312 - Powertrain Data Bus 014 - Defective ------------------------------------------------------------------------------- Address 45: Inter. Monitor Labels: 8E0-951-177.lbl Part No: 8E0 951 177 Component: Innenraumueberw. 0804 Coding: 00001 Shop #: WSC 00000 VCID: 6BD37FBE1992AD79ABD-5120 No fault code found. ------------------------------------------------------------------------------- Address 46: Central Conv. Labels: 8E0-959-433-MAX.lbl Part No: 8E0 959 433 CH Component: Komfortgerát T3B 4035 Coding: 00128 Shop #: WSC 06325 VCID: 79FF55F663CE0FE9291-4AE6 Subsystem 1 - Part No: 8E2959802F Component: Tőrsteuer.FS BRM 0606 Subsystem 2 - Part No: 8E2959801F Component: Tőrsteuer.BF BRM 0606 Subsystem 3 - Part No: 8E0959801E Component: Tőrsteuer.HL BRM 0606 Subsystem 4 - Part No: 8E0959802E Component: Tőrsteuer.HR BRM 0606 No fault code found. ------------------------------------------------------------------------------- Address 56: Radio Labels: 8E0-035-1xx-56.lbl Part No: 8E0 035 186 AA Component: concert II GRO 0004 Coding: 01005 Shop #: WSC 06325 VCID: 66C50E8A02709011F43-4AE6 No fault code found. End-------------------------(Elapsed Time: 13:57)-------------------------- So as far as i could determine its a faulty cluster caused by the shortage in the circuit. And if i understand correctly the immobilizer is integrated in the cluster. Any help and advice would be gladly appreciated. |
SORY help code audi A4 ; AUZ1Z4S6791055
Originally Posted by Audifanstruja
(Post 1493511)
the immobilizer is in the cluster and it looks like your cluster is bad
Originally Posted by Audi Tek
(Post 1493516)
Question is, can i get another cluster from a donor car? I have heard that you cannot use a cluster from a donor car because it is coded for that specific car. What would be the next steps ? |
Hi guys, i am still struggling with the same problem. I lost hope for a while but decided to give it a go again.
So i went to a scrapyard and bought a lock set which includes the cluster,ecu,ignition+key and door lock from the same model car. So i installed and tested it but i still get the same problem, "powertrain data bus defective ??? So what does this mean? Does it mean that i have a problem with my wiring or maybe with some of the other modules ??? My conclusion is one of the above but i dont know. Anyway here is the scan results, hope someone can point me in the right direction. Thanks in advance. Friday,23,December,2016,16:17:59:05981 VCDS -- Windows Based VAG/VAS Emulator Running on Windows 7 x86 VCDS Version: 15.7.4.1 Data version: 20160216 Ross-Tech: Home VIN: WAUZZZ8E08A063068 License Plate: VNG 01 Mileage: 305720km-189965mi Repair Order: Chassis Type: 8E (8E - Audi A4/S4/RS4 B6/B7 (2001 > 2008)) Scan: 01 02 03 08 09 0F 11 15 16 17 18 25 36 37 45 46 55 56 57 65 67 69 75 76 77 VIN: WAUZZZ8E08A063068 Mileage: 305720km-189965miles ------------------------------------------------------------------------------- Address 08: Auto HVAC Labels: 8E0-820-043.lbl Part No: 8E0 820 043 BN Component: A4 Klimaautomat 2833 Coding: 00000 Shop #: WSC 00000 VCID: 6ED576AA2A80584E9C-5102 No fault code found. ------------------------------------------------------------------------------- Address 09: Cent. Elect. Labels: 8E0-907-279-8EC.lbl Part No: 8E0 907 279 N Component: int. Lastmodul ECE 0907 Coding: 01001 Shop #: WSC 06325 VCID: 3D7781E63766F3D655-4ACE No fault code found. ------------------------------------------------------------------------------- Address 16: Steering wheel Labels: 8E0-953-549.lbl Part No: 8E0 953 549 Q Component: Lenksáulenmodul 0701 Coding: 02041 Shop #: WSC 06325 VCID: 418FFD164B9E973631-4AE6 No fault code found. ------------------------------------------------------------------------------- Address 17: Instruments Labels: 8E0-920-9xx-8EC.lbl Part No SW: 8E0 920 901 H HW: 8E0 920 901 H Component: KOMBI+WFS 4 H14 0200 Revision: 0200 Serial number: 00000000000000 Coding: 0006118 Shop #: WSC 73249 020 01196 VCID: 2A5DBABA86E8746E00-5102 1 Fault Found: 01312 - Powertrain Data Bus 014 - Defective ------------------------------------------------------------------------------- Address 25: Immobilizer Labels: 8E0-920-9xx-8EC.lbl Part No SW: 8E0 920 901 H HW: 8E0 920 901 H Component: KOMBI+WFS 4 H14 0200 Revision: 0200 Serial number: 00000000000000 Coding: 0006118 Shop #: WSC 73249 020 01196 VCID: 2A5DBABA86E8746E00-5120 1 Fault Found: 01312 - Powertrain Data Bus 014 - Defective ------------------------------------------------------------------------------- Address 45: Inter. Monitor Labels: 8E0-951-177.lbl Part No: 8E0 951 177 Component: Innenraumueberw. 0804 Coding: 00001 Shop #: WSC 00000 VCID: 6BD37FBE1992AD66BB-513C No fault code found. ------------------------------------------------------------------------------- Address 46: Central Conv. Labels: 8E0-959-433-MAX.lbl Part No: 8E0 959 433 CH Component: Komfortgerát T3B 4035 Coding: 00128 Shop #: WSC 06325 VCID: 79FF55F663CE0FF639-4AE6 Subsystem 1 - Part No: 8E2959802F Component: Tőrsteuer.FS BRM 0606 Subsystem 2 - Part No: 8E2959801F Component: Tőrsteuer.BF BRM 0606 Subsystem 3 - Part No: 8E0959801E Component: Tőrsteuer.HL BRM 0606 Subsystem 4 - Part No: 8E0959802E Component: Tőrsteuer.HR BRM 0606 No fault code found. ------------------------------------------------------------------------------- Address 56: Radio Labels: 8E0-035-1xx-56.lbl Part No: 8E0 035 186 AA Component: concert II GRO 0004 Coding: 01005 Shop #: WSC 06325 VCID: 66C50E8A0270900EE4-4AE6 No fault code found. End-------------------------(Elapsed Time: 11:20)-------------------------- |
| All times are GMT -4. The time now is 06:04 AM. |
