Audi TT 2004 Problem
Old May 16, 2012 | 03:00 AM
Adip Singh's Avatar
Default Audi TT 2004 Problem
Hi guys,
I am having a problem with my Audi TT 2004. We had alot of rains in kenya and the roads were bad, so i didnt drive my TT but did start it every other day.
Afew days ago i started it and the engine did not seem to have power and is cutting off after a few seconds. The Emission control system light ls on even after i start the car. I also am having problems starting the car. I recently changed my car battery in november.
Please help me solve this problem
Old May 16, 2012 | 08:19 AM
M5S5's Avatar
Tech Certified
You will need someone with a scanner to read the fault codes for a start.
Old May 23, 2012 | 08:42 PM
ImTheDevil's Avatar
You may need to adapt the throttle body due to the battery change. M5S5 is right - pull the codes.
Old May 25, 2012 | 04:59 AM
Adip Singh's Avatar
These are the codes that i got.
We checked that there was water in the fuel tank. so we drained all the water and fuel and also now have replaced the Fuel filter.
P0441 fuel evapouration system, flow rate faulty
P0299 boost pressure control, below control limit
P0303 combustion failure cylinder 3 detected
P0304combustion failure cylinder 4 detected
P0302 combustion failure cylinder 2 detected
The car is still jerking while driving
Any suggestions ?
Old May 25, 2012 | 10:52 PM
ImTheDevil's Avatar
You're misfiring in cylinders 2-4. Pull all the spark plugs, dry the cylinders, replace the plugs with new ones (gapped to .032" if the car is stock), clear the codes, and try again. If it misfires again, scan to see which cylinders, and start swapping coil packs around. If the fault codes move with the packs, replace them.
Old May 28, 2012 | 04:39 AM
Adip Singh's Avatar
Thanks for the feedback guys,
Ok... i removed the spark plugs in all cylinders, cleaned and fitted back. As i said before, i changed the fuel filter as well. the car is missfiring as well as the Electronic emmission light is on ( Engine light)
We had a look at the exhaust pipe and the catalytic converter was fine but some sensor cables had been burnt. Could this bee due to the catalytic converter being too hot ?
Could there be a fault in the oxygen sensor ?
Its been a months since the car has been driven and its painfull....
rherman
Sep 27, 2015 06:58 PM
redondodave
Jul 23, 2015 02:48 PM
imthabiz
Dec 20, 2011 06:54 PM
feather618
Oct 4, 2011 01:58 PM
stuartac
Feb 9, 2009 11:04 AM
