Blown cylinder gasket 3.2fsi v6 B8
Old Apr 25, 2016 | 11:20 AM
bennit's Avatar
Default Blown cylinder gasket 3.2fsi v6 B8
I am suspecting my gasket is blown cause im losing coolant rapidly and my oil cap has some "mayonnaise".
1. what causes gasket to fail?
2. roughly how much should i expect to pay to get this fixed? (my warrantee covers me for R 3000.00 on gasket only)
3. must i replace waterpump and thermostat?
Old Apr 25, 2016 | 12:01 PM
dave944's Avatar
Do not drive it.. The coolant mixing in the oil will kill the bearings if it hasn't already. I'm not sure what the cost will be, you'll have to get an estimate first. It's not going to be cheap though knowing how most shops charge these days. Go ahead and replace the waterpump and thermostat if you have it done. It's an extra $60-70 but since the timing belt and such will have to come off to remove the head, you might as well change them out while you're in there. I recommend replacing the waterpump and thermostat whenever you do a timing belt change regardless.
AudiTurbo
Jan 7, 2014 08:03 AM
II IDUA
Dec 4, 2010 09:52 PM
T0NY
Feb 18, 2010 02:05 PM
A4MD
Aug 28, 2007 02:29 PM
A4cabrioB7
Mar 1, 2007 10:13 AM
