Burning oil...no sign of leak
All,
I've had my 2001 A4 1.8T for the last 5 years and I have no complaints. The car is a pleasure to own and drive. I am coming up on 70k miles and I have decided to keep it for the long haul. As a result, I am willing to invest in it more than ever to make sure it can serve me for years to come.
Recent work completed inlcudes full on brake job, timing belt/water pump replacement, tie rod replacement, and oil change.
Here is my current issue: After the work was completed, I noticed blueish/gray smoke coming out of the muffler. It has a gas/oil smell. There are no signs of oil leaks in my garage or on the car, this was confirmed by me and my mechanic. My mechanic also noticed the smokeat idle and mentioned that it is possibly the valve guide seals. The car is burining through oil and the check engine light is on. My mechanic told me it wouldcost about $600-700 more to replace all the seals. He also told me that this was not a 'huge issue' and that I couldget away with adding oil as needed until I can afford the fixes. Isthat true?
It has been about 300 miles since the work and I had to add one quart of oil already. I'm using 5W-30 full synthetic right now, but considering a heavier oil (10W-30) since it is burning off so fast. Is this something I should correct ASAP? Does anyone know what I should expect to pay for this? Finally, what would you do...bite the bullet and replace the seals or just add oil as necessary?
I appreciate your input. Any other general maintenance tips for a 70k mileA4T would be appricatited as well (tune, spark plugs etc). Thanks for helping me keep it alive!
RE: Burning oil...no sign of leak
more and likely valve guid seals...especially if this is at idle and your ading as much oil as u said. also b/c its throwing a code.. if it was a blown turbo seal it wouldnt throw a code.
ORIGINAL: b5gen
"Ur a nuttass... I have a blown K03 running on my car right now. and its not throwing anycodes. So please explain that If your such a smartass. Also seized a k04 turbo in the red a4 below \/ nvr threw a code. SO with that being said i think my first hand experiences prove you wrong.
ORIGINAL: b5gen
Ok, again, sorry for the name calling, it was out of line. We can disagree all we want with out name calling!
