Car Trouble HELP PLease!!!!!!
ok, i have an apointment with the dealer tomorrow mrning.
but dont want to get raped. if anyone can help?
i have a 2000 a6 2.8 quattro
the car vibrates, wont go in to second gear, check engine lite blinks
all the gears light up.
The reading from VAG:
18032
p1624- mil sign active
cylinder 1,2,3,6 misfire
that all
the car wont go any more the 23mph
help!!!!!!!!!!!!!!!!
18032
that all
P1643 means the are stored fault codes that need clearing,
P1143 = load calculation too high possible cause is bad MAF,
p1113 = O2 sensor bank 1 resistance too high,
the car is in limp mode that's why it wont go faster ( MAF is a good place to start ) also the misfire could be caused by that and the O2 sensor reading
ok. thank you for your suggestion.
i disconnected the maf unit(or so i think it was)
as soo as i did, the car shut off. then if i started it wont stay on/
i started snooping around . there is a hose. that runs on top of the engine. THERE'S Smoke COMING OUT OF IT> im FREAKED WTF IS THAT
