Car won't start hot
Old 04-20-2005, 09:27 PM
cdwetz's Avatar
Default Car won't start hot
I have a problem with my Audi A4 Quattro. For some reason my car won't start right away when I have driven it. If the car sits for couple of hours it starts with no problem. It's the time slot between 20mins-1.5hrs where it won't start. Does anyone have an answer to this problem. Also, I have taken my car to get a diaognostic and the mechanic says he can't get a signal. He says the wiring in the car is messed up and it'll take a few hours to find the problem. They charge 99 bucks an hour. Does anyone know what it could be???
Old 04-21-2005, 10:38 PM
AWDaholic's Avatar
Senior Administrator
Default RE: Car won't start hot
The "won't start hot" problem sounds like classic vapor-lock, but that's a carbuerator-type problem. Never heard of it with a "fuelie." With carbs, the quick fix was to pop open the gas cap and put it back on.
As far as the "can't get a signal" thing, I'd say hit another stealership and get a second opinion.
Old 04-22-2005, 04:12 AM
flyboy's Avatar
wont start like won't turnover or won't fire?
Old 07-29-2006, 10:49 AM
Just had the same problem, see if you have enough coolant. Mine was low, added some and never had the same problem again.
Old 07-29-2006, 05:00 PM
binky3000's Avatar
DISTRIBUTOR
Old 07-29-2006, 05:02 PM
EVAP purge valve
Old 07-30-2006, 05:56 AM
fliparto's Avatar
ORIGINAL: lukeazuke
I agree. My car is burning coolant a little, and when its low, it wont start hot
Old 07-23-2009, 04:10 PM
bradfish's Avatar
I'm having the exact same issue...Won't start if it sits longer than ten minutes but less than an hour. I am low on coolant also, going to try this to see if it helps...To the thread starter, did you ever figure the issue out?
Old 07-24-2009, 01:20 PM
bradfish's Avatar
Default Coolant didn't help
Coolant addition didn't help my issue. I'm going to get it looked at for a possible check valve malfunction (leaking gas into the cylinders) or a leaky injector (seems unlikely as Audi told me yesterday when I picked the coolant up that they've NEVER replaced injectors....)
Any other input? Still waiting for the guy that started this to reply, as we have the EXACT problem.
Old 04-10-2010, 09:19 AM
NHN's Avatar
NHN
NHN is offline
Coolant temp sender is the common reason for this fault, about £30 from VAG & mostly diy job, it would be my 1st call anyway
Quick Reply: Car won't start hot
