CEL ON! HELP VAG_COM CODES Oxygen Sensors?
Monday,30,June,2008,20:46:21:27272
VAG-COM Version: Release 704.1 Address 01: Engine Control Module Part Number: Component and/or Version: Software Coding: Work Shop Code: 3 Faults Found: 16514 - Oxygen (Lambda) Sensor B1 S1: Malfunction in Circuit P0130 - 008 - Implausible Signal - MIL ON 16534 - Oxygen (Lambda) Sensor B2 S1: Malfunction in Circuit P0150 - 008 - Implausible Signal - MIL ON 16502 - Engine Coolant Temp. Sensor (G62): Signal too High P0118 - 002 - Lower Limit Exceeded - Intermittent |
RE: CEL ON! HELP VAG_COM CODES Oxygen Sensors?
Reset the codes and see if they return. I think the temperature sensor
is causing all the codes. |
Already did many times, i just ordered a new temp sensor.
looking at the codes I would say that is a good choice
well hopefully is the temp sensor
