CEL P0455 EVAP sys leak: 1998 Audi A4 Quattro Help
Hi,
Just wondering if anyone has any clue as to the problem with Cel P0455 on an 98 Audi A4. Here is the diagnostic report from a code reader: P0455 Evap Emission sys leak detected (gross leak / no flow) misfire ok fuel sys ok comp component ok cat mon inc htd catalyst n/a evap syst mon ok sec air system n/a a/c refrig mon n/a oxygen sens mon inc oxygen sens htr egr system mon n/a I also smell gasoline inside the cabin (definitely different from exhaust gasses). Also, when I get near empty and gas light comes on, after a car restart, gas level goes back to a little over empty and gas light turns off (a definite move in the needle, not just parking on inclines, etc.). Happened about twice before I decided to refuel. I have checked as many vacuum hoses and had a roaming mechanic do the same and no hoses were leaking (but this wasn't a very complete check). Any ideas? I dont feel like spending over a 100 bucks just to diagnose this at the dealership. Thanks! |
I forgot to mention I got the same problem when I lost my gas cap (however cel read large leak, now reads a little different). Replaced it with an aftermarket one and got the code above
The new gas cap may not seal properly.
