Check engine on and blinks, car shakes help
I have a 04 s4 4 door, my check engine started blinking every couple seconds, then stays on and blinks once in a while, at idle the car has slight vibrations, when i accelerate it shakes like heck and in between gears feels like its gonna die , but hasnt yet. At idle rpm seems to be vibrating a little , anyones imput appreciated, going to check codes a lil later, thanks guys
I had a broken mount i never fixed, could this have played a role? Car has 70k |
It just has a cylinder 1 misfire code
Ignition coils are bad
No so fast batman... I had a shop tell me the same thing - they replaced #1 ignition coil and still vibrates - they recommended replacing all coils and still vibrates - I have posted my thread on 6/16 "rough running..." also che:(cked volts to coil and checked ok. Car still sitting on my driveway...
Fix your broken mount you goof. By now you have a problem with something else.
The other mount? Drive train axel, cv joint? |
Each time you check engine light comes on, ALWAYS code reader to find out why. Return to inform you that your computer has detected a "mistake" and it means everything. more audi repair questions at auto md.
| All times are GMT -4. The time now is 10:12 AM. |
