check engine code P0601
I recently had the check engine light go on in my audi a4 2005 code P0601 i looked it up and it says With a P0601 OBD-II trouble code, the most common fix is to replace and reprogram the PCM. In a few cases the dealer may be able to reflash the PCM and get it working. But more than likely the PCM will need to be replaced and reprogrammed (we recommend you take it to a dealership for this)
has anyone done this and what did it cost you thanks. |
i have an code p1176 what can that be?
